[Solved]RC3: File Order bug. MS explorer related.
Locked
marsh
Post by marsh »
1. Put the following files in windows explorer:
2. Configure Xnview browser to sort by name in reverse order.
(z,x,y...)
3. Associate jpg with Xnview.
4. Start viewer by selecting 01.jpg in MS explorer.
5. Now, Xnview will not advance to from 01.jpg to 02.jpg using <page down>.
This is similar to an old file order bug, which was fixed just using browser. But launching
Xnview viewer from MS explorer has problems.
Hacker
Post by Hacker »
Isn't this normal, as opposed to the other case? 01.jpg is the last file for XnView.
Roman
marsh
Post by marsh »
Hacker wrote:Isn't this normal, as opposed to the other case? 01.jpg is the last file for XnView.
Roman
Viewer should acknowledge MS explorer order when launching Xnview viewer directly from
an associated jpg file. It should not impose browser settings on viewer when started this way.
It behaves as expected when starting Xnview browser first and then viewing files from there.
Hacker
Post by Hacker »
marsh wrote:The MS Explorer files are ordered 1,2,3,4. Viewer should acknowledge MS explorer order rather than impose its browser settings onto the viewer. Currently, one must use <page up> to go 1,2,3,4 when launching from MS explorer. Its backwards. If you start with Xnview browser, it works as expected.
How should XnView know about your Explorer sorting order?
Roman
marsh
Post by marsh »
Hacker wrote: How should XnView know about your Explorer sorting order?
Roman
I don't know. V.1.74 acts the same way. Should Xnview know Explorer order when launched
from it?
Dive in mysteries…
:arrow: marsh
:) Hello !
- Like Roman says, this is unknown by XnView… That'ld need to dive in the Dark Mysteries of Windows, that is not obvious… if documented!
- This could be done from Total Commander, though. Just an agreement for this by the two Authors ;)
:mrgreen: Kind regards,
Hacker
Post by Hacker »
marsh wrote:
Hacker wrote:How should XnView know about your Explorer sorting order?
from it?
I don't think it can. Explorer doesn't do anything except run XnView. It doesn't tell XnView about the sort order, your wallpaper or the music playing in winamp. ;)
Roman
Roman
from it?
Sorry but i can't know which file order use windows explorer...
Locked
