XMP does not work in 0.33
GeBu
It looks that XMP does not work in version 0.33.
When I set "XMP" nothink is written.
When I set "XMP update or create IPTC" only IPTC is written.
I mean 'IPTC/XMP edit' dialog.
It looks that IPTC is written ok, because I can see it in Picasa: http://newsgroup.xnview.com/viewtopic.php?f=60&t=21458
mahikeulbody
Re: XMP does not work in 0.33
Same problem for me.
(Windows version)
(Windows version)
I've tried, and i can't reproduce
Could you post a file that you use?
mahikeulbody
The problem occurs with any picture !xnview wrote:I've tried, and i can't reproduce
Take for example this one found through google images : http://www.rdtrisques.org/projets/rizer ... e-rizerili
edit iptc/xmp
set option to xmp only
type some fields : caption, keyword, city, country, etc...
save
No xmp panel appears into xnview GUI and no xmp data is written in the file (checked with Exiftool).
marsh
I can avoid problem by starting program in browser mode, not directly from image in file manager.mahikeulbody wrote: No xmp panel appears into xnview GUI and no xmp data is written in the file (checked with Exiftool).
mahikeulbody
I have the same problem starting program in browser...marsh wrote:I can avoid problem by starting program in browser mode, not directly from image in file manager.mahikeulbody wrote: No xmp panel appears into xnview GUI and no xmp data is written in the file (checked with Exiftool).
Could you send me your .ini, i can't reproduce
You use 'Edit IPTC/XMP' from explorer of XnView?
mahikeulbody
Yes, I use 'Edit/XMP' from explorer of XnView.xnview wrote:Could you send me your .ini, i can't reproduce
I can't reproduce... Could you send me your email by PM...
mahikeulbody
I deleted all folders related to XnViewMP (including Application Data/XnViewMP).
Now XMP works.
It is a little bit strange since XMP was working with 0.32 and the same Application Data/XnViewMP folder.
Now XMP works.
And if you replace with old .ini?mahikeulbody wrote:I deleted all folders related to XnViewMP (including Application Data/XnViewMP).
Now XMP works.
mahikeulbody
With the old .ini it doesn't work.
Ok, i can reproduce now...
GeBu
It does not help me
Now XMP works.
Please check XnViewMP 0.34
