Does not display Sony TIM2 Files with Alpha Channel
Mirrorman95
Post by Mirrorman95 »
Hello, I've been having a constant reoccurring problem with XnView. Most PSP TIM2 files display correctly for me, but ones with alpha channels like http://www.brickshelf.com/gallery/mirro ... h/8082.tm2 and http://www.brickshelf.com/gallery/mirro ... th/708.tm2 do not display properly, and I have to view them in another program such as Noesis. Is there a way to fix this?
Re: Does not display Sony TIM2 Files with Alpha Channel
Could you post a screenshot of correct result?
Mirrorman95
http://www.brickshelf.com/gallery/mirro ... 708out.png
http://www.brickshelf.com/gallery/mirro ... 082out.png
I used oasis.xentax.com's Noesis program to view and convert the tm2 files correctly.
Mirrorman95
This is excellent. The TM2 files with alpha channel are not messed up now, which I must say is an incredible improvement. It does everything I need it to do; generating accurate thumbnails for easy browsing. But for the sake of completeness, you should know that the images I posted did in fact have an alpha channel, and XNView still can't detect this alpha channel on the TM2s.
