MP 0.34 Linux: Detail of a new image in thumbmail view
Roumano
Post by Roumano »
I found something special, with a easy work arround :
1) Via xnvienw, i see i picture need to improve the color via gimp so i open it on gimp then save as on the same directory to not erase the original previon
2) At this moment, xnview detect the new file but can't display the thumbmail & info of the image (like iso, resolultion, size of file, date exif taken,...) on the thumbmail view (but this info are correct on the info pane)
also if a double click on the thumbmail, it not be open on xnview but with the "programme associé" (work correctly if right click / open or the shortcut Ctrl O)
Re: MP 0.34 Linux: Detail of a new image in thumbmail view
Do you have always the problem with 0.35?
Roumano
Post by Roumano »
Yes i still have the problem with the 0.35 version
