Hi
how can i send photos to exiftool with command line?
i read the help web site , did not find an answer
did play with xnview did not find the feature to use exiftool
thanks
cheers
exiftool how can i send photos to exiftool with command line
drugo
Peter2
Re: exiftool how can i send photos to exiftool with command
There is a GUI for exiftool:
http://freeweb.siol.net/hrastni3/foto/e ... oolgui.htm
Take a look.
Peter
Take a look.
Peter
drugo
thanksPeter2 wrote:There is a GUI for exiftool:
Take a look.
Peter
but i found exiftool.exe inside xnview folder
i mean can i use with xnview?
Peter2
??drugo wrote:...but i found exiftool.exe inside xnview folder...
Which version? I just installed 1.97.8 and have no exiftool.exe ...
Maybe a relic of other installations?
Peter
- Forum Librarian
The Windows version of XnViewMP comes with the stand-alone executable of ExifTool (\AddOn\exiftool.exe).Peter2 wrote:??drugo wrote:...but i found exiftool.exe inside xnview folder...
Peter2
That is the difference: MP ..XnTriq wrote:The Windows version of XnViewMP ....
Peter
