Folders should not be draggable in Viewer mode
budz45
Post by budz45 »
Currently in MP 0.34 win, folders from Win Explorer are drag-able onto the Viewer mode interface....
Dragging folders is ok for the Browser mode but not ok for the Viewer mode (IMO).
There should be a block on dragging 'folders' to the Viewer mode with showing of cursor block like FastSton Image Viwer does it on attempting to drag a 'folder'
thank you
Re: Folders should not be draggable in Viewer mode
Please check XnViewMP 0.38
budz45
Post by budz45 »
Resolved, fixed :D
