0.34 crash on .java files
stenosis
Post by stenosis »
Hi, I'm running the 0.34 XnViewMP version on Linux 64bit and it does crash on me when i open up a folder which contains .java files even when i set it up not to display any kind of text files in the browser. Can anyone confirm this?
cheers
wubijacq
Re: 0.34 crash on .java files
Post by wubijacq »
what sorts of java files .jar files?
stenosis
Post by stenosis »
it's enough to create an empty text file with the ending .java to crash xnviewmp 0.34 for me.
stenosis wrote:it's enough to create an empty text file with the ending .java to crash xnviewmp 0.34 for me.
I can't reproduce...
stenosis
Post by stenosis »
i've shot a quick demo video of the situation:
http://www.youtube.com/watch?v=cDBrYd8G_UQ
Could you start XnViewMP in a console, and post the end of output?
stenosis
Post by stenosis »
Sorry for the late response, here's the output of the crash on version 0.35:
stenosis@knecht:~/.Anwendungen/XnViewMP$ bash xnview.sh
`menu_proxy_module_load': /home/stenosis/.Anwendungen/XnViewMP/xnview: undefined symbol: menu_proxy_module_load
(<unknown>:3118): Gtk-WARNING **: Failed to load type module: (null)
(<unknown>:3118): Gtk-WARNING **: /usr/lib/gtk-2.0/2.10.0/immodules/im-ibus.so: falsche ELF-Klasse: ELFCLASS64
(<unknown>:3118): Gtk-WARNING **: Loading IM context type 'ibus' failed
XNVIEW restoreGeometry before : 640 480
XNVIEW restoreGeometry after : 1336 903
w.init
XNVIEW SIZE 1336 903
########### BrowserWindow :: BrowserWindow
MENU install : a2e1e48
### ThumbLoaderThread :: stop()
QLayout: Attempting to add QLayout "" to QWidget "", which already has a layout
QWidget::setMinimumSize: (favoriteD/QDockWidget) Negative sizes (0,-1) are not possible
QWidget::setMinimumSize: (categoryD/QDockWidget) Negative sizes (0,-1) are not possible
QWidget::setMinimumSize: (prevD/QDockWidget) Negative sizes (0,-1) are not possible
########### BrowserWindow :: ok create (640 480)
BrowserWindow :: changeVisibility()
BrowserWindow :: updateMenu()
########### BrowserWindow :: restoreState (1336 903)
XNVIEW resize : 1336 903
## MyTabWidget :: resizeEvent : 1336 903
## RESIZE: 902 494
### MyBitmapView (a3d2720) :: resizeEvent 100 78
## RESIZE: 1336 870
### BrowserWindow :: onStart
BrowserWindow :: onStart 2
setPathname </home/stenosis/.Anwendungen/XnViewMP/>
## OPEN FOLDER
## OPEN FOLDER ok
## updateLabels
## updateLabels ok
### ThumbLoaderThread :: setFileList()
### ThumbLoaderThread :: setFileList() wait
######ThumbLoaderThread :: run : a321398
######ThumbLoaderThread :: forever : a321398
### ThumbLoaderThread :: setFileList() ok
######ThumbLoaderThread :: start : 11
ThumbLoaderThread => 1 (-1 -1)
DB (1) : 4096 4096
ThumbLoaderThread - LOADED from DB (1)
ThumbLoaderThread - loadThumb from DB (1 - AddOn)
######ThumbLoaderThread :: start : 10
ThumbLoaderThread => 2 (0 11)
DB (2) : 4096 4096
ThumbLoaderThread - LOADED from DB (2)
ThumbLoaderThread - loadThumb from DB (2 - language)
ThumbLoaderThread => 3 (0 11)
DB (13) : 4096 4096
ThumbLoaderThread - LOADED from DB (13)
ThumbLoaderThread - loadThumb from DB (13 - lib)
ThumbLoaderThread => 4 (0 11)
DB (14) : 4096 4096
ThumbLoaderThread - LOADED from DB (14)
ThumbLoaderThread - loadThumb from DB (14 - Plugins)
ThumbLoaderThread => 5 (0 11)
DB (15) : 4096 4096
ThumbLoaderThread - LOADED from DB (15)
ThumbLoaderThread - loadThumb from DB (15 - UI)
ThumbLoaderThread => 6 (0 11)
LOAD BITMAP </home/stenosis/.Anwendungen/XnViewMP/README>
MyDirModelThread :: run
setPathname </home/stenosis/>
## OPEN FOLDER
## OPEN FOLDER ok
## updateLabels
GFF :: LoadThumbnail : 2
ThumbLoaderThread => 7 (0 11)
DB (16) : 8604 8604
ThumbLoaderThread - LOADED from DB (16)
ThumbLoaderThread - loadThumb from DB (16 - xnview_2.png)
ThumbLoaderThread => 8 (0 11)
DB (22) : 8830 8830
ThumbLoaderThread - LOADED from DB (22)
ThumbLoaderThread - loadThumb from DB (22 - xnview.png)
ThumbLoaderThread => 9 (0 11)
LOAD BITMAP </home/stenosis/.Anwendungen/XnViewMP/XnView.desktop>
## updateLabels ok
######ThumbLoaderThread :: start : 9
DB (3) : 4096 4096
ThumbLoaderThread - LOADED from DB (3)
ThumbLoaderThread - loadThumb from DB (3 - Bilder)
QFileSystemWatcher: failed to add paths: /home/stenosis/
######ThumbLoaderThread :: start : 8
ThumbLoaderThread => 2 (0 9)
DB (4) : 4096 4096
ThumbLoaderThread - LOADED from DB (4)
ThumbLoaderThread - loadThumb from DB (4 - Desktop)
ThumbLoaderThread => 3 (0 9)
DB (5) : 4096 4096
ThumbLoaderThread - LOADED from DB (5)
ThumbLoaderThread - loadThumb from DB (5 - Dokumente)
ThumbLoaderThread => 4 (0 9)
DB (6) : 16384 16384
ThumbLoaderThread - LOADED from DB (6)
ThumbLoaderThread - loadThumb from DB (6 - Downloads)
ThumbLoaderThread => 5 (0 9)
DB (7) : 4096 4096
ThumbLoaderThread - LOADED from DB (7)
ThumbLoaderThread - loadThumb from DB (7 - Dropbox)
ThumbLoaderThread => 6 (0 9)
DB (8) : 4096 4096
ThumbLoaderThread - LOADED from DB (8)
ThumbLoaderThread - loadThumb from DB (8 - Musik)
ThumbLoaderThread => 7 (0 9)
DB (9) : 4096 4096
ThumbLoaderThread - LOADED from DB (9)
ThumbLoaderThread - loadThumb from DB (9 - �ffentlich)
ThumbLoaderThread => 8 (0 9)
DB (10) : 4096 4096
ThumbLoaderThread - LOADED from DB (10)
ThumbLoaderThread - loadThumb from DB (10 - Videos)
ThumbLoaderThread => 9 (0 9)
LOAD BITMAP </home/stenosis/crashit.java>
GFF :: LoadThumbnail : 3
/usr/lib/gio/modules/libgvfsdbus.so: falsche ELF-Klasse: ELFCLASS64
Failed to load module: /usr/lib/gio/modules/libgvfsdbus.so
ThumbLoader :: thumbLoaded 1
ThumbLoader :: thumbLoaded 2
ThumbLoader :: thumbLoaded 3
ThumbLoader :: thumbLoaded 4
ThumbLoader :: thumbLoaded 5
###### onChildrenChecked 7 <�ffentlich>
###### onChildrenChecked 5 <Musik>
ThumbLoader :: thumbLoaded 6
ThumbLoader :: thumbLoaded 7
ThumbLoader :: thumbLoaded 8
ThumbLoader :: thumbLoaded 9
xnview.sh: Zeile 5:  3118 Speicherzugriffsfehler  "$dirname"/xnview "$@"
Which linux do you have?
Do you have the same problem with 32bits version?
