Hi
While converting JPEG to PNG i'm facing a problem.On converting
JPEG images of sizes (300 to 900 KB) into PNG the nconvert expands its sizes & resolution(3 to 5 MB) & Converting JPEG of Size(more than 3 MB) nconvert compressed its size (in KB).
Is there any option for JPEG(upto 1 MB of size) should remains its original size(i.e. doesnt expands) after conversion into PNG.
thnx
JPEG Image Compression problem
Re: JPEG Image Compression problem
You can try different level of compression, but jpeg is lossy and png losslessAltaf Raza wrote:While converting JPEG to PNG i'm facing a problem.On converting
thomas59310
Ok, but How to change compression level with nconvert?
xnview wrote:You can try different level of compression, but jpeg is lossy and png losslessAltaf Raza wrote:While converting JPEG to PNG i'm facing a problem.On converting
-qthomas59310 wrote:Ok, but How to change compression level with nconvert?
p43k
thank you.xnview wrote:-qthomas59310 wrote:Ok, but How to change compression level with nconvert?
