MP 0.34 Linux: Batch convert, text
jarom
Post by jarom »
First of all thanks for this great piece of software.
I have found a bug that shows up when trying to add multiline text to the picture using batch convert. It seems like the bounding box for the text is calculated for one line text.
Steps to reproduce the bug:
1. Select picture in browser
2. Ctrl + I
3. Write three lines of text in the Caption box
4. Save
5. Ctrl + U
6. Actions -> Image -> Text
7. Select Text as IPTC - Caption -> Caption
8. Look at the preview
As far as I can tell the bug is present also in earlier versions of XnView MP. There's no such bug in standard XnView.
Second thing - normally one can't enter multiline text in the textbox using keyboard. It is however possible to paste multiline text prepared elsewhere. In such case bounding box is also too small for text to fit inside. I would love to see the behaviour from XnView where multiline texts are rendered properly and the text box is multiline.
Best regards
Jaromir
Re: MP 0.34 Linux: Batch convert, text
Please check XnViewMP 0.35
jarom
Post by jarom »
Thank you!
Now it's almost perfect.
Almost because text align seems to be center regardless from the setting.
You are doing really good job with this software.
Best regards
Jaromir
