Add text diagonally
taksina
Add text diagonally
Post by taksina »
Hi all,
I'm attempting to add text on top of a picture and am wondering whether it's possible to place the text block diagonally across, say, the top half of the picture? As it is now, I can only figure out how to do that horizontally.
Thanks in advance,
Taksina
marsh
Re: Add text diagonally
Post by marsh »
Create seperate image of text, rotate it, and use it along with watermark function? I'm not sure what that result would look like though.
DOS386
Post by DOS386 »
> Add text diagonally
Sure it is possible, it's just painful ...
I did not test the "watermark" feature, but separate rotation of the text and then merging it in "some way" is the way to do for now. Alternatively you can 2 x rotate the picture, but this will damage quality - useful only if you plan to zoom down then.
http://newsgroup.xnview.com/viewtopic.php?t=15701 "Add text" 2008-Aug
The problem is that XNVIEW and NCONVERT do outsource the font/text work to Windows. The ideal solution is native font/text handling in the library and reusing it in XN and NC, this would work on every platform and give same results everywhere. Once you have it, adding ZOOM, rotation, transparency, colors, styles (italic with variable angle, ...) & Co would be rather easy.
marsh
Post by marsh »
I am not able to add text upon the transparent background of a png (perhaps unique to my OS). A workaround using watermark would be possible within program otherwise:
Drahken
Post by Drahken »
One workaround would be stepped text. Open the paint filter to put some text in, then put the first letter in, hit enter to go to the next line, space a few times to get to the right position, then type the second letter, go to the next line, space, thrid letter, etc, etc. It's tedious & not the exact effect you're looking for, but it gets similar results, and is easier than making it as a seperate image, rotaing, etc.
