Change timestamp bug in sort by "name (numeric)"...
ghost zero
Post by ghost zero »
When the browser is in sort by "name (numeric)", change timestamp changes a group of selected files as if it's in sort by "name" only. Therefore, the order of timestamp change is not correctly applied. Can this be fixed?
BTW: I change the modified date.
Re: Change timestamp bug in sort by "name (numeric)"...
I don't understand, the order of files for 'change timestamp' is not important
ghost zero
it is important because when i switch sorting mode to by "modified date", then the thumbnails sorting order isn't consistent with how it was when it was sorted by "name (numeric)" and applied the timestamp changes. i want them to be consistent because i frequently switch between these two modes of viewing thumbnails. i frequently apply the timestamp changes to batches of downloaded images and sort them by "name (numeric)" then apply the timestamp changes, so that their order will be maintained when viewing in "modified date" mode. currently, this works fine when working in sort by "name" but not for when working in sort by "name (numeric)". can this be fixed?
What do you use in 'change timestamp'?
ghost zero
i use...
- current date and time
- file date modified
Oh ok, i understand...
ghost zero
can this be fixed in next version?
I've checked again, but all seems correct. 'Change timestamp' take order of file list in thumbnail view...
ghost zero
i frequently come across the problem. try testing with this sample group of images and you will be able to reproduce the problem...
File Name: test pics.zip
http://www.sendspace.com/file/k6yr4c
I can't reproduce, i have the same order with 'name (numeric)" & 'date' after change timestamp
ghost zero
did you apply "modified date = current" to all images at once?
i'm always able to reproduce the problem on my system. in case my settings matter, here is my xnview 1.97.8 .ini file. you should be able to reproduce the problem with my setup...
File Name: xnview.ini
http://www.sendspace.com/file/yqq6ax
No :(
Could you send me a screenshot of files in detail mode after 'change timestamp'?
ghost zero
here are screenshots. first is sorted by "name numeric" and second is by "date". this was after a change timestamp applied to all at once and they're supposed to be sorted the same in both screenshots, but notice they're not because of the bug...
Ok, i can reproduce...
