MP 0.34 Win: File list options don't always work
JohnFredC
budz45
Re: MP 0.34 Win: File list options don't always work
Known unresolved issue.
Annoying one at that as I myself only want to go though image files of a file list in the Viewer mode and not other file-types whatsoever.
I know that this will get fixed eventually.
strange, i can't reproduce. Do you use Filter>Custom??
JohnFredC
Hi Pierre
To exclude text files (*.txt) from the browser, I MUST use Filter>Custom. The Filter>Text check boxes don't appear to work.
John
I can't reproduce, txt files are hidden for me...JohnFredC wrote: To exclude text files (*.txt) from the browser, I MUST use Filter>Custom. The Filter>Text check boxes don't appear to work.
JohnFredC
OK, sorry for the delay.
1. Including txt extension in custom works properly
2. Using the "Text" file type category does not work properly
- • Open browser
• Navigate to a folder with text files
• Open Settings->Browser->Filelist
• Remove "txt" from the custom categories if present
• For the "Text" category, set "Visible" and "Show as thumb" to TRUE
• Click OK
• Observe that text files are displayed in the browser file panel
• For the "Text" category, set "Visible" and "Show as thumb" to FALSE
• Click OK
• Observe that text files are still displayed in the browser file panel
.John
I've tried, but i can't reproduce
TXT files are hidden with your step...
JohnFredC
Hi Pierre
Maybe I don't understand and it isn't a bug?
Here you can see I have disabled all the File List text boxes, but the text files are still visible.
Notice that in the image the browser filter is set to "Custom". A strange behavior is that every time I attempt to select "All" in the filter combo box, the result becomes "Custom". Perhaps the two behaviors are related?
This screenshot is of the 0.38, May 31, version.
John
Vapavite
I do not understand this:
Message title: MP 0.34 Win: File list options don't always work
End of message: This screenshot is of the 0.38, May 31, version .
Available version at:
XnViewMP Version 0.35 beta (unstable) (Jan 14 2011)
Is there a version 0.38 or clerical error
(French)
Titre du message : MP 0.34 Win: File list options don't always work
Fin du message : This screenshot is of the 0.38, May 31, version.
Version disponible sur le site :
Y a t'il une version 0.38 ou erreur d'écriture
(French)
Vapavite @+
JohnFredC
2Vapavite
Pierre sent me that version to test a bug specific to my system. It is not "ready for prime time". AFAIK there is not a general release later than 0.35...
John
I can't reproduce, txt files don't appear
Do you have txt in the text extensions list?
JohnFredC
Yesxnview wrote:I can't reproduce, txt files don't appear
But here is the solution to this bug:
If the user selects "All" in the Browse filter combo, MP sets the "Custom" check mark in the filter combo!
It only "looks like" custom mode has been selected, when actually the filter is set to "All"!
"All" is never reported by the filter combo.
So... when I enter a folder and inspect the filter, "Custom" is checked, but all files show. I must select (click-on) "Custom" to apply the custom filter (of course!). To remove the filter I must select "All", but the checkmark remains at "Custom"!
A simple bug, sorry I didn't catch it before. Getting old.
John
Really?? And with View>Filter>All? When i click on Filter>All, the good entry is selected..JohnFredC wrote: If the user selects "All" in the Browse filter combo, MP sets the "Custom" check mark in the filter combo!
JohnFredC
Yes, I have tried this over and over:
Can others confirm?
- 1. Click View->Filter by...->Custom
2. Observe file list shows Custom files only
3. Observe View->Filter by... "Custom" is checked.
4. Observe "mini" toolbar filter combo: "Custom" is checked.
5. Click View->Filter by...->All
6. Observe file list shows ALL files
7. Observe View->Filter by... "Custom" is checked!
8. Observe "mini" toolbar filter combo: "Custom" is checked!
Can others confirm?
John
yes please try? I can't confirm...JohnFredC wrote:Can others confirm?
