Request: On enter folder behaviors
JohnFredC
Post by JohnFredC »
In MP currently (0.34) no image is selected when entering a folder in the browser.
Please implement (at least) that MP selects the first image (in the file list) when the user enters a folder.
A useful alternative would be to offer a setting with which the user could choose from the following behaviors upon entering a folder:
  • (•) Select first image
    ( ) Select last image
    ( ) Do nothing
John
marsh
Re: Request: On enter folder behaviors
Post by marsh »
Or done by rule without option: if first item is image - show it (otherwise do nothing).
Please check XnViewMP 0.38
JohnFredC
Post by JohnFredC »
Sorry, but I have tested extensively and can observe no change in behavior (when entering a folder) between version 0.35 and 0.38.
On the other hand, the addition of ratings etc. to the filter dropdown is most welcome!
John
marsh
Post by marsh »
The new option is below:
Browser>[x]Select first item on entering folder
JohnFredC
Post by JohnFredC »
Thanks Marsh, I must have looked at that option 10 times without seeing it. Perhaps the default value should be "On"...
John
marsh
Post by marsh »
I agree. That favors an image viewer over organizer behavior (toward which I wish the overall purpose of program does not weigh too heavily).
