Scan to folder
DrEd
Scan to folder
Post by DrEd »
I just started using Xnview. I am using it to scan receipts into folders. What I do is to open the folder and then do a scan but the scan does not go into the folder. Is there a setting for this? At this time it scans it and then you have to specify the folder to save it to. This is not efficient, especially if I have multiple documents that I want to scan into the same folder. Thanks.
RickS
Re: Scan to folder
Post by RickS »
DrEd wrote:I just started using Xnview. I am using it to scan receipts into folders. What I do is to open the folder and then do a scan but the scan does not go into the folder. Is there a setting for this? At this time it scans it and then you have to specify the folder to save it to. This is not efficient, especially if I have multiple documents that I want to scan into the same folder. Thanks.
File>Acquire Into>Directory
The directory you choose should remain the same.
