Same emf file, different -info
fgamboa
Post by fgamboa »
Hi:
I'm upgrading from nconvert 3.72 to 5.75 and my emf files converted to jpg are significant degraded, I think because the emf file is badly reconigzed in 5.75 version.
This is the comparison with:
nconvert -info f1.emf
3.72 5.75
Format : Windows Enhanced metafile Windows Enhanced metafile
Compression : Uncompressed Uncompressed
Width : 4800 Width : 767
Height : 6282 Height : 1001
Nplanes : 1 Bytes Per Plane : 4
Bitscount : 24 Bits per component : 1
Depth : 24 Depth : 1
# colors : 16777216 # colors : 2
Bytes Per Plane : 14400 Color model : RGB
Orientation : Bottom Left Orientation : Bottom Left
Xdpi : Not set Xdpi : 96
Ydpi : Not set Ydpi : 96
Page(s) : 1 Page(s) : 1
windows explorer give similar 3.72 emf file properties data.
with 5.75 when I convert to jpg, and view or print the image is degraded no matter how parameters I use for conversion.
With 3.72 teh conversin was fine.
Can you help me?
Tanks in advance.
Fco Gamboa
PD.- Where can I send the sample enf file?
Re: Same emf file, diferente -info
Could you send me a sample?
fgamboa
Post by fgamboa »
Hi pierre:
I've sent the file to your wanadoo.fr mail box.
regards
Fco Gamboa
Pleas use contact at xnview dot com
But no attachment in your email :-(
fgamboa
Post by fgamboa »
Hi Pierre.
You can get teh sample from:
www.progama.com.mx/f1.emf
regards
Fco Gamboa
fgamboa
Re: Same emf file, different -info
Post by fgamboa »
Hi Pierre:
with 5.80 Release, all seems fine.
Thanks
Fco Gamboa
