ability to edit EXIF name or date/hour
Irving
Post by Irving »
No doubt this has been asked before, but I've searched the site until my eyes are bleeding. Forgive the repetition.
How about the ability to add or remove your name in the EXIF?
And thanks to the morons again messing with Daylight Savings Time, :x :evil: I'd like to be able to change the hour in the EXIF. (I have a bunch of Christmas parade images with the wrong info)
Re: ability to edit EXIF name or date/hour
Irving wrote:How about the ability to add or remove your name in the EXIF?
What do you means by 'your name'??
Irving
Post by Irving »
With Canon's, (well, at least with the ones I know of, the A510, the A710, and the SX100) it's Owner name. Example:
Camera Manufacturer : Canon
Camera Model : Canon PowerShot SX100 IS
Orientation : top-left (1)
X Resolution : 180
Y Resolution : 180
Resolution unit : Inch
Date modified : 2010:11:28 14:55:26
YCbCr Positioning : centered (1)
Exposure time : 1/1250
F-Number : 5.6
ISO speed ratings : 80
EXIF version : 02.20
Date taken : 2010:11:28 14:55:26
Date digitized : 2010:11:28 14:55:26
Components configuration : YCbCr
Compressed bits per pixel : 5
Shutter speed : 1/1244
Aperture : F5.6
Exposure bias value : -1/3
Max aperture : F4.3
Metering mode : Multi-segment (5)
Flash : No flash
Focal length [mm] : 60
FlashPix Version : 01.00
Colour space : sRGB
EXIF image width : 3264
EXIF image length : 1832
Interoperability offset : 3362
Focal plane X-Resolution : 43520/3
Focal plane Y-Resolution : 1832000/169
Focal plane res. unit : Inch (2)
Sensing method : One-chip color area sensor (2)
File source : DSC
Custom rendered : Normal process (0)
Exposure mode : Manual (1)
White balance : Manual (1)
Digital zoom : 1
Scene capture type : Standard (0)
IOP index : R98
IOP version : 0100
IOP width : 3264
IOP height : 1832
Macro : Normal
Selftimer : Off
Compression setting : Super fine
Flash mode : Not fired
Drive mode : Single or timer
Focus Mode : Single
Image size : Unknown
Easy shooting : Manual
Contrast : Normal
Saturation : Normal
Sharpness : 0
ISO value : 80
Metering mode : Evaluative
Focus type : Auto
AF point : Unknown
Exposure mode : Program
Lens Type : 65535
Long focal : 60000
Short focal : 6000
Focal units / mm : 1000
Max aperture : 135
Min aperture : 192
AutoISO : 100
BaseISO : 79
MeasuredEV : 367
White balance : Sunny
Slow shutter : Off
Sequence number : 0
Flash Bias : 0 EV
Image number : 101-131
Owner name :
LensID : 6000 60000
Compression : 6
X Resolution : 180
Y Resolution : 180
Thumbnail offset : 5108
Thumbnail length : 3720
Irving
Post by Irving »
Bump.
kaon
Edit/Remove location coordinates too
Post by kaon »
I've wanted to have edit EXIF for these other reasons:
Case 1:
Photos taken by iPhones and other smartphones often have GPS coordinates in EXIF, this is sometimes useful, but sometimes needs to be removed before publishing online.
Batch deletion of location coordinates would be useful.
Case 2:
I've had a photographer take hundreds of photos for me, but the EXIF had the wrong date/time due to him not setting the internal clock of the camera.
It would have been useful to be able to edit the time as a batch, by say adding for example: 2 years, 4 months, 5 days, 6 hours, and 7 minutes to each of the photo's EXIF.
heraldo
Post by heraldo »
I'd like to be able to edit Exif in general, but especially being able to remove the "Software" info from all my photos, I don't like how every other editor just adds that line without asking me.
