Batch resize changes orientation
mdalacu
Post by mdalacu »
Hi, in XNView when you batch resize photos it will auto orient the resized photos. In XNViewMP it does not. I have tested this (found this bug) using phpAlbum . Is this the intended behavior?
Thank you.
Anyway this tool is making my Ubuntu perfect! :D
Re: XnViewMP beta 0.34
mdalacu wrote:Hi, in XNView when you batch resize photos it will auto orient the resized photos. In XNViewMP it does not. I have tested this (found this bug) using phpAlbum . Is this the intended behavior?
Thank you.
What do you means by auto orient?? When file has EXIF orientation? Could you post a sample?
mdalacu
Post by mdalacu »
xnview wrote: What do you means by auto orient?? When file has EXIF orientation? Could you post a sample?
Hi, i have uploaded an archive witch contains 3 photos and the batch profile from XnViewMP.(EDIT: i can upload only 2MB so i've removed the original, if you need it i will post it somehow).
The resize in XnView will change the orientation in EXIF, also rotate the jpeg, in XnViewMp something is wrong because in phpAlbum (i think it does not auto orient jpeg) the picture looks wrong (horizontal).
could you send me it
mdalacu
Post by mdalacu »
xnview wrote: could you send me it
This is the only solution i've fount to upload it. Sorry. I hope it helps.
http://rapidshare.com/files/441146341/Test.zip
Thanks.
mdalacu
Post by mdalacu »
Thanks.
Any info regarding my problem ?.
Thank you.
Thanks.
Thank you.
will be fixed
