Ignore extension for Find similar files...
eL_PuSHeR
Post by eL_PuSHeR »
Hello. I am using XnView 1.97.8 under Windows XP SP3.
I have found out that if I have the same image (same filename) in two different formats in the same folder (01.jpg and 01.png) for instance «Find Similar Files... -> same filename » will not be able to find out it's the same image. An option to ignore extension would come in handy.
Best regards.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
GeForce GTX 970 (Gigabyte)
Re: Ignore extension for Find similar files...
eL_PuSHeR
Post by eL_PuSHeR »
I wrote the same file as PNG and TIFF on the same folder. It works properly now (make sure "use extension" box is ticked of course).
Thank you very much!
Intel i7 5960X
8 GB DDR4 (2100)
