I have been using PP for many years. I have a new computer with WIN 7 and have been having a lot of problems with the PP and Win 7. After doing some research, I came across XnView with it's great reviews. So I am going to try it. I do like all the documentation. So when I load files from my PP, many of them are PDF files. Of course I can't get them opened. So what do I have to do to get them opened or converted? The "convert to" does not seem to do the trick. Also, is there a way to scan directly to the folder that is open in the pane? I am sure there will be more questions to come, but for now these would help a lot.
Michael
Moving from PaperPort to XnView
Re: Moving from PaperPort to XnView
To be able to load PDF, you must install ghostscript, see FAQ 'How to display vector formats like PDF, AI,...? GhostScript!' .
