REQ: drag and drop out of viewer window
scratch
could you implement a feature so that either left or right mouse drag (one or the other, i'm fine with either) out of the viewer window will enable to you drag and drop the file into another program? this is already the way it works in the browser.
Re: REQ: drag and drop out of viewer window
When you are in edit/view mode, to be able to drag the opened picture in another program?scratch wrote:could you implement a feature so that either left or right mouse drag (one or the other, i'm fine with either) out of the viewer window will enable to you drag and drop the file into another program? this is already the way it works in the browser.
Dreamer
Dreamer
consistency
but thats no problem,Dreamer wrote:If you'd add "drag and drop out of viewer window" option (with LMB and RMB) you would not be able to make selection with LMB and move zoomed image with RMB.xnview wrote:Sorry, what is it?Dreamer wrote:And what about Make selection and Move large image?
tools > options > general > keyboard/mouse
there is a nice drop down menu in the mouse section, every user can choose himself which option the mouse buttons should offer them.
i don't need both offered options (make selection, move picture), but another person will need it. i need the drag'n'drop feature there.
so please, please add this option there. its really unhandy to close fullscreen view only to drag'n'drop a file to another application.
yes i know the option to "open with" but thats not enough, i dont drag pic only to one application, some applications dont support "open with". often i drag and drop a picture from xnview to winscp -> open with is sensless here. so i have to leave the fullscreen mode, wait for building up the browser view (yes its slow sometimes), locate the picture in the thumbnail list and then drag it in the prog.
i beg you, please add the drag'n'drop feature to the (fullsceen)-view, it would help a lot. it is only a addition, no feature is removed with this option. make the other options (make selection, move picture) the default options but make it possible to choose drag'n'drop there.
consistency
