MP 0.35 Mac: Batch Convert menu and zoom anomalies
rbarker
Post by rbarker »
Hello...
I am running XnView MP 0.35 on Mac OS X 10.6.6 on the first Intel-based Macbook Pro 17"
In Batch Convert, Actions, Processing; when I press + and hover on Image, Map, Filter or Misc, the pop-out menu appears, but often quickly disappears. If I time moving the cursor to the right, and hover over the long menu that pops out, that will stay. However, many times I'll have to click + to get the menus to reappear.
Also, in Batch Convert, under Actions and Preview, usually both the - and + magnifying glass icons will zoom-in. I have to click Best Fit in order to zoom-out.
Thanks,
Robert.
Re: MP 0.35 Mac: Batch Convert menu and zoom anomalies
rbarker wrote: In Batch Convert, Actions, Processing; when I press + and hover on Image, Map, Filter or Misc, the pop-out menu appears, but often quickly disappears. If I time moving the cursor to the right, and hover over the long menu that pops out, that will stay. However, many times I'll have to click + to get the menus to reappear.
Ok
I can't reproduce, i have zoom in and zoom out...
rbarker
Post by rbarker »
Hi... I took another look at the zoom in and out behavior I reported. When I go to Batch Convert, Actions, Preview, and Load Image--it turn out the image I load will zoom properly. However, when I apply "Resize" to the Processing area the Zoom misbehaves.
