i tried to convert several files in a folder structure. These files are from the type jpg and orf (olympus raw format). But when i select the folder to convert all the files, the dialog only adds the jpg-files to the batch job. Any ideas?
Heiko
Batch-Job only on JPG-Files?
Hausmeister2000
Re: Batch-Job only on JPG-Files?
I now found a solution with nconvert and a batch file:
The xcopy command copys all files from "test" to "test_output" excluding folders and filetypes named in "no_copy.txt".
The complete folder structure in "test_output" is the same as in "test" after xcopy finished.
The for command runs through the new folder structure and converts all files to jpg and overwrites existing jpgs and deletes all other filetypes (for example olympus raw).
Greets
Heiko
xcopy C:\temp\test C:\temp\test_output /e /v /s /exclude:no_copy.txt
for /R C:\temp\test_output %%I IN (*.*) do C:\Programme\XnView\nconvert -overwrite -resize 1920 1080 -ratio -out jpeg -D %%I
Greets
Heiko
marsh
Like you first reported, I don't see orf files included in listing for <add folder> button (unlike cr2, nef). All appear in list by highlighting items in browser's file list + <ctrl + u>.
marsh
orf now appears in list. v.1.98.b1
