I created some web galleries using 'Create' -> 'Web Page...' from the menu of XnView Browser.
All my graphic files have the numbering character '#' inside their filenames.
I created the web page using the template 'Pixnview [black]'.
Everything worked fine with one exception. The '#PIC_LINK#' macro inside the template does not escape the '#' character to %23 and the whitespace to %20.
Other macros work properly. Here the macro and the result inside the html file:
original filename: "2010.05.29 Unsere Hochzeit - Standesamt #002.jpg"
"#PIC_LINK#" -> "2010.05.29 Unsere Hochzeit - Standesamt #002.jpg"
some examples where it works properly:
"#PREV_PAGE#" -> "2010.05.29%20Unsere%20Hochzeit%20-%20Standesamt%20%23123.html"
"#THUMB_LINK#" -> "thumbs/2010.05.29%20Unsere%20Hochzeit%20-%20Standesamt%20%23002.jpg"
I guess the PIC_LINK macro is simply not escaped, but it should be.
Best Regards and thanks for XnView
Martin
PS: This is problematic because Firefox(3.6.13) does not load the image when the '#' is not escaped (IE does it).
PS #2: XnView Version 1.97.8
bug when creating web pages from files with a # in filename
xnMartin
xnMartin
Re: bug when creating web pages from files with a # in filen
tested it today with the final of v1.98 and everything is escaped now as expected.
Thank you very much for your support.
Regards
Martin
Regards
Martin
