Saving Multiple Captures
David Bethel
Post by David Bethel »
Greetings,
Just found your software and so far I am very impressed.
Is there a way to save multiple screen captures in a single operation?
Lets say you have made 4 captures in the proper order:
Do you have to save each <Capture-nn> tab independently or is there a saveall ?
TIA -David
Re: Saving Multiple Captures
You can use "save in" in capture dialog
David Bethel
Got it!
Thanks! -David
