Hi, when I view a given jpg-Picture with xn-View and View The Same Picture in Photoshop they Look quite different. The Picture in xnview Looks sharper, but with more granulat. Maybe in xnview The contrast is higher, or there are less colors Used. Has this been noticed by Somerset of you, also? Does anyone Know Why this is and of there is a Way to correct this?It is Odd to See The Same Picture differently with two viewers. Thanks for help. Best regards
Jens
Different look of pictures
oops66
Re: Different look of pictures
Depends of your settings, especially if Options\View\Hight Quality zoom is activated or not, gamma correction, icc profiles, ...etc...
haunje
I tried all these switches, but without solving this problem (I restarted xnview after changing the parameters, also).
Have anyone of you seen the same problem at all? The picture in xnview shows pixels and in other programs like Photoshop not?
Regards
Jens
Regards
Jens
- Forum Librarian
Differences in the display of JPEG images can sometimes also be the result of varying decoders.
