crashed with custom filers enabled
harumscarum
MP crashed every time if custom filers enabled. for example if i open folder with non-image files
harumscarum
Re: crashed with custom filers enabled
how to run Mp in "safe mode" because i getting it crashed as soon as i start it
on which OS?harumscarum wrote:how to run Mp in "safe mode" because i getting it crashed as soon as i start it
harumscarum
windows7 x64bit
If custom filers is not used, no problem?harumscarum wrote:windows7 x64bit
harumscarum
yeah, i dont enable custom filters so it possible to use MP.xnview wrote:If custom filers is not used, no problem?
by the way how to associate all image files with MP? i'd like to use it instead XnView
I can't reproduce, could you post a screenshot of Option>File list?harumscarum wrote:yeah, i dont enable custom filters so it possible to use MP.xnview wrote:If custom filers is not used, no problem?
