w7 32 + XnView v1.97.8 and nVIDIA GeForce 7300 GS
Goaul
Post by Goaul »
On fresh installed PC w7 32bit, XnView v1.97.8 Standard version(also tried older versions) on open changes resolution and color setting, when xnview is closed all settings all back normal (1680x1050).
This issue doesnt occur with XnViewMP.
Also tried reaname xnview.ini, and opening xnview was again the same issue.
    CPU Properties:
      CPU Type                                          DualCore AMD Athlon 64 X2 3800+
      CPU Alias                                         Windsor-512
      CPU Stepping                                      JH-F2
      Engineering Sample                                No
      CPUID CPU Name                                    AMD Athlon(tm) 64 X2 Dual Core Processor 3800+
      CPUID Revision                                    00040F32h
    CPU Speed:
      CPU Clock                                         1994.6 MHz  (original: 2000 MHz)
      CPU Multiplier                                    10x
      CPU FSB                                           199.5 MHz  (original: 200 MHz)
      HyperTransport Clock                              797.8 MHz
      Memory Bus                                        249.3 MHz
      DRAM:FSB Ratio                                    CPU/8
    CPU Cache:
      L1 Code Cache                                     64 KB per core  (Parity)
      L1 Data Cache                                     64 KB per core  (ECC)
      L2 Cache                                          512 KB per core  (On-Die, ECC, Full-Speed)
    Motherboard Properties:
      Motherboard ID                                    63-371-0000010-00101111-032610-ATI$ASRO2371_ALIVEXFIRE-ESATA2 BIOS P3.80
      Motherboard Name                                  ASRock ALiveXFire-eSATA2  (3 PCI, 1 PCI-E x1, 2 PCI-E x16, 4 DDR2 DIMM, Audio, Gigabit LAN)
    Chipset Properties:
      Motherboard Chipset                               AMD 480X CrossFire, AMD Hammer
      Memory Timings                                    4-4-4-12  (CL-RCD-RP-RAS)
      Command Rate (CR)                                 2T
      DIMM1: A-Data                                     1 GB DDR2-667 DDR2 SDRAM  (5-5-5-15 @ 333 MHz)  (4-4-4-12 @ 266 MHz)  (3-3-3-9 @ 200 MHz)
      DIMM2: A-Data                                     1 GB DDR2-667 DDR2 SDRAM  (5-5-5-15 @ 333 MHz)  (4-4-4-12 @ 266 MHz)  (3-3-3-9 @ 200 MHz)
    BIOS Properties:
      System BIOS Date                                  03/26/10
      Video BIOS Date                                   03/08/06
      DMI BIOS Version                                  P3.80
    Graphics Processor Properties:
      Video Adapter                                     nVIDIA GeForce 7300 GS
      GPU Code Name                                     G72GS  (PCI Express 1.0 x16 10DE / 01DF, Rev A3)
      GPU Clock                                         552 MHz  (original: 550 MHz)
      Memory Clock                                      351 MHz  (original: 350 MHz)
    NVIDIA Control Panel 266.58
    NVIDIA Graphics Driver 266.58
    NVIDIA Install Application
    nvapi.dll                  8.17.12.6658                NVIDIA NVAPI Library, Version 266.58
    nvcompiler.dll             8.17.12.6658                NVIDIA Compatible Compiler, Version 266.58
    nvcpl.dll                  7.17.12.6658                NVIDIA Display Properties Extension
    nvcuda.dll                 8.17.12.6658                NVIDIA Compatible CUDA Driver, Version 266.58
    nvcuvenc.dll               8.17.12.6658                NVIDIA CUDA Video Encoder, Version 266.58
    nvcuvid.dll                8.17.12.6658                NVIDIA CUDA Video Decode API, Version 266.58
    nvd3dum.dll                8.17.12.6658                NVIDIA Compatible Vista WDDM D3D Driver, Version 266.58
    nvdispco322050.dll         2.0.5.0                     Display Driver Coinstaller
    nvdispco322090.dll         2.0.9.0                     Display Driver Coinstaller
    nvgenco322030.dll          2.0.3.0                     Generic Coinstaller
    nvgenco322040.dll          2.0.4.0                     Generic Coinstaller
    nvmctray.dll               8.17.12.6658                NVIDIA Media Center Library
    nvoglv32.dll               8.17.12.6658                NVIDIA Compatible OpenGL ICD
    nvshext.dll                1.2.0.1                     NVIDIA Shell Extensions
    nvsvc.dll                  8.17.12.6658                NVIDIA Driver Helper Service, Version 266.58
    nvsvcr.dll                 8.17.12.6099                NVIDIA Driver Helper Service, Version 260.99
    nvwgf2um.dll               8.15.11.8593                NVIDIA Compatible D3D10 Driver, Version 185.93
Any solution?
Re: w7 32 + XnView v1.97.8 and nVIDIA GeForce 7300 GS
XnView change your resolution????
Goaul
Post by Goaul »
Yes it does and colors are set like some 256. Any tips to help resolve this?
like i said before, by just opening xnview with shortcut on desktop (after fresh installation) resolution and colors are changed, and when xnview is closed all is back normal again.
trash101
Post by trash101 »
Could it be compatibility settings under windows? Check those by right clicking on the shortcut or on the actual EXE file.
the problem is not in XnView, perhaps something with windows settings??
Goaul
Post by Goaul »
Thx to everyone who tried to help :)
Checked compatibility and it helped, after new compatibility settings were applied, the issue was gone.
G
