The new version is great!
But I have got a question.. What size is a preview picture?
When I enlarge the size of the preview, for example 384 x 288 pixels, the preview pictures look like "pixelled".
It looks as if the preview picture is enlarged when zoomed.
A bigger preview picture is not take into account, I take it?
When giving order "rebuilt thumbnails" there is no change.
Is it possible to calculate a preview picture of more (or higher) resolution?
Best regards
ftomasch
Thumbnails size
Re: Thumbnails size
Do you means preview or thumbnail??
ftomasch
Re: Thumbnails size
I mean only Thumbnails.
ftomasch
ftomasch
Re: Thumbnails size
is it possible to have a file to check?
ftomasch
Re: Thumbnails size
Hallo.
I have found the solution.
The cause was that the button "use embeddet thumbnail" was activated.
Best regard
ftomasch
Best regard
ftomasch
