Hello Exerrts,
I am using .NET environment. In my allpcation i want to convert CDR file.
Is this possible me to convert CRD files programitically using batch processing of xnview.
What are the downlaods for it and what is the batch commend.
Please help me. Thanks in advance.
Convert CDR file to EPS
niteensapkal
Re: Convet CDR file to EPS
Thank you sir. Is there any way to achieve this?
Peter2
CDR = Corel Draw?niteensapkal wrote:Thank you sir. Is there any way to achieve this?
Peter
Yes, CDR are Corel Draw files. XnView can display the embedded preview of Corel Draw files, only.Peter2 wrote:CDR = Corel Draw?niteensapkal wrote:Thank you sir. Is there any way to achieve this?
Peter
XnView does and cannot support this format, because the format is proprietry (not disclosed and made public by the "manufacturer").
See topic Handling limited Corel format support for further links and information.
