[Bug report] System hang on compressed file searches
syaoran-kun
Post by syaoran-kun »
Hi, i just spotted this problem so i thought i'd report it here.
When you select a .7z compressed file, and double click it to explore, the program hangs completely and takes down the entire operative system with it. I've tested this few times, same outcome.
Is this a bug or a known issue? (i couldn't find anything similar in the bugreport forum). Filename of the folder and the subfolder inside the 7z are in japanese.
Running Windows 7 64 bit - X2 4600+ - 2GB RAM - GeForce 7900GTO Running the latest Xnview
Re: [Bug report] System hang on compressed file searches
Could you send me the .7z?
syaoran-kun
Well..my upload is kinda bad and the 7z is ~700MB. I have torrented it, would be ok if i linked you the torrent? (magazine scans).
Are you able to make a little .7z file and reproduce the crash?
