[Solved] "Find similar files": dialogue to small
Peter2
Post by Peter2 »
The dialogue for "Find similar files" is too small - and it can not be increased.
n:\ow\the problem\is if\you have\incredible long\pathes\in your\network
you can not see the end of the string: no increasing, no scrolling, no tool tip .. :(
Please improve it :idea:
Thanks
Peter
Re: "Find similar files": dialogue to small
Peter2
Re: [Solved] "Find similar files": dialogue to small
Post by Peter2 »
Solved in 1.98. beta 1
Peter
