Inverted order of copied thumbnails
sosalista
Post by sosalista »
Hello, when I select more thumbnails and copy them via clipboard into a MS Word document, they get pasted in inverted order. Is there a simple way to copy them in the same order as displayed in XnView? Thanks a lot for any help!
Re: Inverted order of copied thumbnails
I've tried with notepad, and they are in the good order...
sosalista
Post by sosalista »
Hi, do you mean the notepad that's part of Windows accessory programmes and doesn't display anything but plain text? I need to copy the thumbnail images not the file names so as to work with them later on in MS Word...
I can't test with MS Word, but images are copied into clipboard in the good order...
