In XnView MP, it says "Close" and "Apply" in various dialogs. Instead of "Close" and "Apply" it should say "OK" and "Cancel". And: "OK" button is to the left of "Cancel" button.
Windows standard for buttons in modal dialogs is:
"OK" is for confirming and closing a modal dialog.
"Cancel" is for canceling and closing a modal dialog.
"Apply" is used when settings/changes made should be applied without closing the modal dialog.
UI: Close & Apply should be OK & Cancel
budz45
Re: UI: Close & Apply should be OK & Cancel
Do you mean like in menus like from the menu bar Image>Adjust>'shadow & highlight' the "Close" and "Apply" there?
If so I understand what you mean
Yes, that dialog for example. It's wrong in many places:budz45 wrote:Do you means like in menus like from the menu bar Image>Adjust>'shadow & highlight' the "Close" and "Apply" there?
Tools > Search...
Tools > Export...
Tools > Batch Convert..
Tools > Upload on web
Image > Change Colour depth...
Image > Solarize...
Image > Enhance Colors...
budz45
Yes your certainly right. I think too, that it should be 'OK' and 'Cancel' especially for the inclusion of the 'Cancel'...
Not to worry, though, as all Pieree would have to do on this issue is a simple name change. The functions would remain the same
Do you agree with that? I'm ok for Close=>Cancelhelmut wrote: Yes, that dialog for example. It's wrong in many places:
Tools > Search...
Tools > Export...
Image > Solarize...
JohnFredC
I think of three actions:
- • Close dialog and apply changes
• Close dialog but do not apply (i.e., abandon) changes
• Apply changes but do not close dialog
John
Vapavite
Yes Helmut. The term "Close" is still ambiguous in a dialog!
FR : Appliquer | Annuler | OK (pas Fermer!)
"Apply" is used when the settings / changes must/ be applied without closing the modal dialog box.
"Apply" is used when the settings / changes are required or permitted (preview) be applied without closing the modal dialog box.
Overview if the three buttons : Apply | Cancel | OK"OK" is for confirming and closing a modal dialog.
So yes xnveiw!"And:OK" button is to the left of "Cancel" button.
NB : The Apply button will be necessary only under certain conditions!Do you agree with that? I'm ok for Close=>Cancel
Vapavite @+
Please check XnViewMP 0.38
JohnFredC
budz45
Well John, see and compare for yourselfJohnFredC wrote:What has changed, exactly?
MP 0.35
VS.
MP 0.38
So in English XnViewMP, it's now 'ok' & 'cancel' instead of 'apply' & 'close' ------just a small cosmetic name change can make a big difference in apps. Not fully sure about all the other areas of MP where this should have been updated too.
PS.> Just one tiny thing, in the 'Export' window (launched from Browser) it still says 'close' instead of 'cancel'.
JohnFredC
