[Solved] TIF to PDF: huge file size
Peter2
Post by Peter2 »
I converted TIF to PDF.
Filesize of TIF: 150 - 250 kB
Filesize of PDF: 17 -18 MB
And changing the settings (LZW, FAX, ZIP, ..) has no result - all the files are the same, only date and title are different.
Peter
PS: Optimizing the files with PDF Tools reduces the size vom 17 MB to 310 kB.
Peter2
Re: TIF to PDF: huge file size
Post by Peter2 »
Hello Pierre
some comment? Here is an excellent tool to convert "Image to PDF": http://noliturbare.com/
Peter
Peter2
Re: [Solved] TIF to PDF: huge file size
Post by Peter2 »
Peter2 wrote:...And changing the settings (LZW, FAX, ZIP, ..) has no result - ....
Fixed. Here are the results for "Convert TIF to PDF with different settings":
I like the JPEG-result ... :mrgreen: :mrgreen:
1.TIF                   7630
1_FAX.pdf               8518
1_JPEG.pdf          33056585
1_LZW.pdf              62235
1_Packbits.pdf        477080
2.TIF                   7640
2_FAX.pdf               8528
2_JPEG.pdf          44090069
2_LZW.pdf              71136
2_Packbits.pdf        616672
3.TIF                   7678
3_FAX.pdf               8568
3_JPEG.pdf          88209506
3_LZW.pdf             106027
3_Packbits.pdf       1165159
4.TIF                   6196
4_FAX.pdf               7083
4_JPEG.pdf          20420930
4_LZW.pdf              45414
4_Packbits.pdf        307100
5.TIF                   6077
5_FAX.pdf               6959
5_JPEG.pdf           9887313
5_LZW.pdf              35191
5_Packbits.pdf        173673
6.TIF                 193596
6_FAX.pdf             194493
6_JPEG.pdf         154759609
6_LZW.pdf             360668
6_Packbits.pdf       2427880
7.TIF                 341311
7_FAX.pdf             160111
7_JPEG.pdf         183790959
7_LZW.pdf             381041
7_Packbits.pdf       2715418
8.TIF                  25176
8_FAX.pdf              25969
8_JPEG.pdf          21964987
8_LZW.pdf             125899
8_Packbits.pdf        462485
Peter
Strange for the jpeg, is it a RGB picture?
Peter2
Post by Peter2 »
xnview wrote:Strange for the jpeg, is it a RGB picture?
No, a black/White scan with 400 TIF.
Peter
Ok, so it's normal, JPEG convert it in greyscale
