Hi all !
If you add MP to SendTo context menu and put in an image... MP crashes with this message:
Firma problema:
Nome evento problema: APPCRASH
Nome applicazione: xnview.exe
Versione applicazione: 0.0.0.0
Timestamp applicazione: 4d3040b9
Nome modulo con errori: xnview.exe
Versione modulo con errori: 0.0.0.0
Timestamp modulo con errori: 4d3040b9
Codice eccezione: c0000005
Offset eccezione: 002459f0
Versione SO: 6.1.7600.2.0.0.256.48
ID impostazioni locali: 1040
Informazioni aggiuntive 1: 0a9e
Ulteriori informazioni 2: 0a9e372d3b4ad19135b953a78882e789
Ulteriori informazioni 3: 0a9e
Ulteriori informazioni 4: 0a9e372d3b4ad19135b953a78882e789
Leggere l'informativa sulla privacy online:
http://go.microsoft.com/fwlink/?linkid= ... cid=0x0410
Se l'informativa sulla privacy online non è disponibile, leggere quella offline:
C:\Windows\system32\it-IT\erofflps.txt
MP 0.35 for Windows 32 "Send To" crash
Re: MP 0.35 for Windows 32 "Send To" crash
How do you add MP to the 'Send to' menu?
quaid
In Send To folder I made a simply windows link to xnviewMP.exexnview wrote:How do you add MP to the 'Send to' menu?
When I send it an image, xnviewmp opens ( in full screen mode ) and more often crashes with the message I've posted.
I've tried but no crash. If you drag&drop the picture file on XnViewMP icon, do you have a crash?quaid wrote:In Send To folder I made a simply windows link to xnviewMP.exexnview wrote:How do you add MP to the 'Send to' menu?
quaid
I've got the error I posted, and if I run the exe directly, Mp Aero border window doesn't appear, I see only the menu.
Yes... I've used ctrl + F11 for Aero Border... my mistake.
I've updated Windows 7 and deleted the .ini MP file now MP works... I don't know how.
