probleme sauvegarde [French]
alex1er
Post by alex1er »
Bonjour Pierre
Je tente d'ouvrir une image en tant que miniature et essayer de la sauvagarger mais le resultat est vide.
Je passe un bout de code si quelqu'un a une idée du probleme
Merci
GFL_BITMAP GFL_Preview;
	gflLoadMiniature(100, 100, "c:\\clement.jpg", &GFL_Preview);
	gflSaveImage(&GFL_Preview, "c:\\copy_clement.jpg");
void gflLoadMiniature(int iWidht, int iHeight, char * szPath, GFL_BITMAP * GFL_Preview)
	GFL_ERROR err;
	GFL_LOAD_PARAMS load_params;
	GFL_FILE_INFORMATION m_file_information;
	gflGetDefaultLoadParams(&load_params);
	//gflGetDefaultThumbnailParams(&load_params);
	load_params.Flags |= GFL_LOAD_PREVIEW_NO_CANVAS_RESIZE;
	load_params.Flags |= GFL_LOAD_METADATA;
	load_params.Origin = GFL_TOP_LEFT;
	load_params.ColorModel = GFL_RGB;
	load_params.LinePadding = 3;//4
    err = gflLoadPreview (szPath,
                            iWidht,
                            iHeight,
                            &GFL_Preview,
                            &load_params,
                            &m_file_information);
void gflSaveImage(GFL_BITMAP * GFL_bitmap, char * szPath)
	GFL_SAVE_PARAMS save_params;
	GFL_ERROR err;
	gflGetDefaultSaveParams(&save_params);
	save_params.Quality=100;
	/*save_params.Compression = GFL_NO_COMPRESSION;
	save_params.OptimizeHuffmanTable = 1;*/
	save_params.FormatIndex = gflGetFormatIndexByName("jpeg");
	err = gflSaveBitmap(szPath, GFL_bitmap, &save_params);
MaierMan
Post by MaierMan »
no french here.
anyway:
#include "libgfl.h"
#include <iostream>
bool verify(const char *act, GFL_ERROR err)
	using namespace std;
	bool v = err == GFL_NO_ERROR;
	cout << act
		<< (v ? "OK" : gflGetErrorString(err))
		<< endl;
	return v;
// use a pointer to a GFL_BITMAP pointer in order to get the real address
// your way "loses" the pointer
// this is actually a wrapper function
// and IMO arguments for wrapper functions that are simply passed thru should have same type (pointer-wise)
// than the underlying function excepts ;)
bool gflLoadMiniature(int iWidth, int iHeight, char *szPath, GFL_BITMAP **GFL_Preview)
	gflGetDefaultPreviewParams(&load_params);
	return verify(
		"load",
		gflLoadPreview(
			szPath,
            iWidth,
            iHeight,
            GFL_Preview,
            &load_params,
            NULL
bool gflSaveImage(GFL_BITMAP * GFL_bitmap, char * szPath)
	return verify(
		"save",
		gflSaveBitmap(
			szPath,
			GFL_bitmap,
			&save_params
int main()
	gflLibraryInit();
	// Same here... use a pointer... gflsdk will allocate the bitmap struct itself
	GFL_BITMAP *GFL_Preview;
	if (gflLoadMiniature(100, 100, "test.jpg", &GFL_Preview))
		gflSaveImage(GFL_Preview, "t_test.jpg");
		gflFreeBitmap(GFL_Preview);
	gflLibraryExit();
	return 0;
alex1er
Post by alex1er »
Thanks it works
