CTRL-P and the print-symbol does'nt work
mdahn
Hi! I have the problem, that I can't print XnView. It works fine in the past. We installed new printer-network-driver (sharp). The funny thing is, that all other programs works fine. We can print and CTRL-P works too. We removed the programm, cleans the registry for 3 times, but it' still the same. If we use the Print-Button, XnView finished and we are on the desktop. Can erverybody help
BR md
Re: CTRL-P and the print-symbol does'nt work
CTRL+P or File>Print => no dialog??
mdahn
Nothing - close direct XnView and thats it. !?
md
md
Do you have tried to rename the xnview.ini?
mdahn
Yes Sir! But with the new xnview.ini it's the same problem - no dialog - close ncview and thats it ...
could you send me your email by PM?mdahn wrote:Yes Sir! But with the new xnview.ini it's the same problem - no dialog - close ncview and thats it ...
mdahn
Do you got my eMail-adress?
