list of image files with resolution
tassos
Post by tassos »
is there a way to use nconvert with a directory of images to create an ascii or uniformat text list for those files in the form <filename> <x-pixels> <y-pixels> :?:
in case this is not currently possible:
(a) is there another utility that will perform the above task ? :wink:
(b) is it possible in xnview ?
thanks in advance :D
Re: list of image files with resolution
You have 'generate file listing' in XnView 1.97
