Modified feature suggestion
mjbiggs
Post by mjbiggs »
Hello
Have been trying out XnView MP and thinks it's great, especially with regard to the detail display of exif metadata.
It is the only application I have found so far, able to display image ratios as column data.
My suggestion, or rather request, is that the 'ratio' column display may be customizable - to display 2 or 3 decimal points throughout, say. At the moment ratios are displayed either as fractions, 1 decimal point, or 2 decimal points.
For me, the 'holy grail' would then be to rename files by appending their decimal ratio to their existing file names.
mjb
Re: Modified feature suggestion
In ratio column you would like to have something like 1.33 instead of 4/3?
