Convert PPS slides to Jpg format
create
Post by create »
Can anyone tell me how to convert pps slides into a single set of slides in one go. ie not having to select each slide and convert it? :D
Re: Convert PPS slides to Jpg format
create wrote:Can anyone tell me how to convert pps slides into a single set of slides in one go. ie not having to select each slide and convert it? :D
You must open each pps slide to convert it
Raphael Barbosa
Post by Raphael Barbosa »
Try it:
1 - Option A: One file to DCX with all pictures
* Select the PPS or PPT file you want to convert. You don't need to open it.
* Click menu create, option multi-page file
* Choose a folder and a filetype (I'd suggest Zsoft Multipage Paintbrush). Unfortunatelly, there isn't a option for creating GIF.
* Click create
2 - Option B: Two steps to DCX selecting slides
* Open the PPS or PPT file you want to convert. You need to open, don't just select it in Navigation mode.
* Go in menu tools, option multipage file and click in extract all in...
* Choose a folder and a filetype. I'd suggest BMP because there will be less lost of quality or even no lost (I do not recommend JPG because it's lossy. See this FAQ for more information. BMP is larger in bytes but you will delete BMP files after conversion. So it's TEMP, ok?
* Click OK and wait a little until finished.
* Close file, open the folder you've choosen in last step, select the files from the original PPS/PPT (they're named after PPS/PPT filename i.e. if PPS was Summer.ppt, the files would be Summer_page_001, Summer_page_002, Summer_page_003, and so on).
* You can add some more files if you want so.
* Go to menu create, option multi-page file
* Reorder the sequence if you want.
* Click create
Raphael Romero Barbosa
