Converting huge files (example TIF to PDF/JPG) displays different progress information:
The progress-bar (bottom of dialogue) displays approx. 10-20% "more percent" then the information in title-bar of the window. (Example: 80% down, 60% in title)
Peter
Different percent-progress
Peter2
Peter2
Re: Different percent-progress
Peter2
IMHO the difference comes from wrong refreshing commands. After an input-file is converted the progress on the bottom is refreshed; the progress on the top is refreshed after the conversion of the second file.
Peter
Peter
Do you have tried the batch convert in XnView 0.48?
Peter2
Yes. There it is different. The posting above concerns XnConvert 1.10.xnview wrote:Do you have tried the batch convert in XnView 0.48?
But I see that the calculation of remaining time is based on number of input files. That's a problem with multi-page files where one file has 3 pages and the next files has 120 pages. A perfect solution would be:
- Count the number of all existing pages
- Calculate the progress based on the number of existing and exported pages.
Peter
This can be very slow to count the total number of pages...Peter2 wrote: But I see that the calculation of remaining time is based on number of input files. That's a problem with multi-page files where one file has 3 pages and the next files has 120 pages. A perfect solution would be:
Peter2
If I use TotalCommander in a directory with total 18 PDF and 33 MB and enable the user-defined columns (using plugin xpdfsearch), then I have in 3 sec infos in each file about width, height, page count, file version, author.xnview wrote:This can be very slow to count the total number of pages...
But maybe a calculation is a kind of "fake-feature". Exact or not - the duration stays the same ....
Peter
Peter2
XnConvert 1.20:
Seems that the progress-info has refresh-problems (Input: 2 PDF with total 27pages)
The display at top and at bottom is displayed once, the progress-bar jumps from 0 to 100 in one step.
But more files show that there is a description "done" is missing in the caption:
Peter
Peter
