Fit image to windows
TGB_72
I would like that XnView fit every image (no matter the size) to the window but I select "fit image to windows" and only works for the current image since when I continue navigating trough the folder some small images are not fit to the window, any idea how to solve this. I tried all options on View=>Auto Image Size. I'm using Xnview 1.97.8 on Win7 32bits.
marsh
Re: Fit image to windows
I cannot recreate problem. There are also seperate settings in Options... View>Fullscreen and Menu... Preview depending on how image is viewed.
TGB_72
Thanks you marsh, selecting "fit image to windows" from View>Fullscreen works fine, meaning that it apply definetely this view mode for all images. Otherwise the option in the menu view "auto image size" only works for the current picture.
marsh
I just had the same problems by accidentally changing setting.
- Distinguishing auto image sizes
