Security settings when exporting PNG
Nurio
Post by Nurio »
Whenever I use XnView to export any image to PNG, a lock appears over the file. This is because, for some reason, XnView exports the PNG file without any rights for normal Users. This is something that only happens for PNG export. It doesn't happen when you Export as JPG or if you Save as PNG. Here are images to illustrate it:
The original file. A PNG
The file, after exporting as PNG
Because there are no read/write rights for normal Users.
(Kudos if you can identify my wallpaper)
I've already tried running XnView as administrator, but that didn't work. Any ideas on how to fix this?
I am running:
Windows 7 Professional SP1 32-bit
XnView v1.97.8
Graphics card: Nvidia Quadro FX 770M
Re: Security settings when exporting PNG
I can't reproduce, do you use 'export' or 'save as'?
Nurio
Post by Nurio »
I use 'Export'. 'Save as' works just fine the way it should.
I don't have any other image editing software on my laptop besides MS Paint, so I don't think that interferes either.
I have K-lite Codec Pack installed, but that shouldn't cause a problem.
i've tried but no problem...
Nurio
Post by Nurio »
Now that's just strange... I'll check on my end to see what could be wrong.
Nurio
Post by Nurio »
I've looked into my system, but really couldn't find anything wrong...
And now I also get these locks when I export to JPG. This is so strange...
Nurio wrote:I've looked into my system, but really couldn't find anything wrong...
and only by Export??
Nurio
Post by Nurio »
Yes, only by Export. But I've noticed a "pattern" now.
This only happens whenever I press Refresh before saving (I have Auto refresh off). If I don't Refresh before saving, everything's fine.
