IPTC stripped
obelisk
IPTC stripped
Post by obelisk »
Using 'clean metadata' if IPTC isn't selected but EXIF is, then IPTC info is still stripped in the output.
I'm converting JPG->JPG
IPTC contained copyright info from camera.
:bug:
marsh
Re: IPTC stripped
Post by marsh »
I cannot recreate problem with my samples. Do you have any for forum? Or screen capture? I thought camera info belonged in Exif tab.
Re: IPTC stripped
Please send a sample picture file?
obelisk
Re: IPTC stripped
Post by obelisk »
it's a jpg created by dxo. I get exif info, and in the iptc tab I get just author+copyright + 2 numbers. I'll send a sample tonite.
