Wrong colour with CR2 files
YippieYeah
Post by YippieYeah »
hey guys, I wanted to switch from faststone viewer to this one, but xnview displays the raw files wrong... see picture.
and also takes a little longe rto preview images. any clue how to fasten the previewing of images?
http://www.riccardo-ulpts.com/xnview.png
Re: Wrong colour with CR2 files
Do you have tried to change option/View>Misc - Camera raw option
YippieYeah
ok, this worked, i used embedded option now.
but half and full size dont work, why? For new users this is a lot trouble to go through maybe u should change default option to option one?
YippieYeah
One more problem, when a double click a picture, to open it, i have wrong colours again :-(
I think it might be due to the new raw standard of Canon 550d.... I needed to update camera raw as well for photoshop.
YippieYeah
http://www.riccardo-ulpts.com/IMG_7045.CR2
I just found out it works with option one: embedded (at least for preview)
but with option 2: half size and 3) full size (sorry im using german version and dont know th eenglish expression) i get the pinkish colour, where there should be white colour. (with preview)
Opening the picture itself, not in browser view, again doesnt work as it displays the full size cr2 file.
ok, right there is a problem. FastStone has the same problem if you don't use embedded jpeg
YippieYeah
ok cheers.... by the way, where do i quickly see the ratings and set those, underneath images ? that would help a lot to organise them.
also.... is comparing of pictures possible or coming?
YippieYeah wrote:ok cheers.... by the way, where do i quickly see the ratings and set those, underneath images ? that would help a lot to organise them.
You have rating as little icon on the thumbnail
Tools>Compare
