XnView random refresh screen XnViewMP not
quaid
Post by quaid »
When I run XnView, in Catalog mode Edit mode or full screen mode It refreshes ( shakes ) randomly the screen... the effect is the same you see when refresh windows desktop ( the icons disappear for about 0.5 seconds ).
In mine case If I view ( e. g. ) a sequence of images in full screen mode, some images of sequence "refreshes" without a reason and randomly... not all images and not the same if I repeat the sequence.
As I said this "refresh issue" or shake issue or dither issue appear also in catalog mode and edit mode, randomly.
I've tested this issue appears on Windows 7 32 bit ( on Seven 64 the images are stable ). I've tested with fresh xnview.ini file but the behavior is the same.
XnViewMP doesn't have this.
Someone can help me or explain why ?
XnView 1.97.8
Windows 7 32bit
