I have my own files on drive F:, system drive is C:
With the option file list>parent folder unvisible
and filter>images
changing to drive C: in the folder tree makes XnViewMP crash.
With another filter setting OR with parent folder visible it doesn't crash.
Edit: Couldn't start the program any more at all, it instantly crashed after start.
After setting showHiddenFiles in the ini file to false it worked again.
[MP035win] crash under special circumstances
bege
Re: [MP035win] crash under special circumstances
you go to c:\?
Perhaps a special file that cause the crash?
Which OS do you have?
bege
yesxnview wrote:you go to c:\?
I don't know. Perhaps any system file?xnview wrote:Perhaps a special file that cause the crash?
Windows XP SP3xnview wrote:Which OS do you have?
