Command line options of XnConvert 1.0?
Forseti
Post by Forseti »
Thanks for Help!
Re: Command line options of XnConvert 1.0?
XnConvert file1 file3 file3
or
XnConvert @filelist
Forseti
Post by Forseti »
What are the silent install parameters of the new setup wizard ?
WALLOON
Post by WALLOON »
I don't understand.
Is it possible to use XNCONVERT in batch mode ?
I use interactively to resize an image :
I save the scritp and see the batch file.
nconvert -ratio -rtype mitchell -resize 160 219
Now I want to resize many files in batch :
I try this one :
"C:\Program Files\XnView\nconvert" "C:\CLIENTS\collardbovy\mysql\dbf\images\br-d693.jpg" -ratio -rtype mitchell -resize 160 219
but the process gives me some error ?
Conversion of C:\CLIENTS\collardbovy\mysql\dbf\images\br-d693.jpg into C:\CLIENT
S\collardbovy\mysql\dbf\images\br-d693.jpg OK
Error: Can't open file (-ratio)
Error: Can't open file (-rtype)
Error: Can't open file (mitchell)
Error: Can't open file (-resize)
Error: Can't open file (160)
Error: Can't open file (219)
Could you give me some help ?
Thank you
Remy
There is no silent option for setup
WALLOON wrote:I don't understand.
I try this one :
NConvert not XnConvert, right?
the good command is nconvert -ratio -rtype mitchell -resize 160 219 br-d693.jpg
