Using progress callback
Peter_K
Post by Peter_K »
Hello.
I'm trying to use progress callback procedure while loading a picture.
Here is the code (modified example from GflSDK\Delphi\Demo\Source\):
procedure ProgressCallback(percent: GFL_INT32; user_params: Pointer); stdcall;
begin
  Application.MessageBox('Procedure is called', 'OK', MB_OK + MB_ICONINFORMATION);
end;
procedure LoadPicture(FileName: string);
begin
  lp.Callbacks.Progress := ProgressCallback;
  e := gflLoadBitmap(PChar(FileName), gfl_bmp, lp, finfo);
end;
The picture loads successfully, but procedure ProgressCallback is never called. What am I doing wrong?
Maybe, something must be assigned to TGFL_LOAD_PARAMS.Callbacks.ProgressParams, but I haven't found any description of this parameter or code that uses it.
Thank you in advance.
AmigoJack
Yahoo Messenger: amigojack_tuneman
Re: Using progress callback
Post by AmigoJack »
Works fine for me. I guess you forgot to call this, which is needed to initialize GFL_LOAD_PARAMS:
gflGetDefaultLoadParams( lp );
Peter_K
Post by Peter_K »
No, I had this line, but procedure still wasn't called.
In my project, which is pretty much simple, I've walked around the problem with one of these gifs: http://www.cinemamuseum.ir/images/ajax-loader.gif
But I've never managed to run my callback function.
