I'm using v 1.97 on Vista. How do I keep XnView from making a dinging sound every time I select a thumbnail in the browser?
This is the best free program available for dealing with graphic files by the way. It's amazing all the functionality it contains. GREAT JOB!
Dinging sound selecting a thumbnail in the browser?
RastusWashington
Re: Dinging sound selecting a thumbnail in the browser?
dinging sound??? You click on a thumbnail and you have a sound?
RastusWashington
Yeah. Every time I click on a thumbnail I hear a ding sound. It's an OS system ding sound. I looked in the sound control panel for XnView but it's not there.
XnView don't make sound when you select thumbnail, which OS?
RastusWashington
Thanks for the reply.
I'm using Vista. I've had it do this for several versions now. It drives me crazy but the program is so good I put up with it. Typically programs will show up in my OS control panel and allow me to turn off certain sounds. I guess because the dings are not meant to be there XnView does not show up in the control panel. Obviously it's an aberrant thing I'll just live with unless you know of a way to fix it.
Thanks
Thanks
really strange, you are the first user with this problem.
Could you make a screen movie?
RastusWashington
Whats the easiest way to make a screen movie in Vista?
• You could use a free software like i.e. DemoStudio.
- It works fine with XP-Pro, but I don't know with Vista (it might do, though…)
PS to Pierre : The soft I quote is the continuation of CamStudio which I think is no more maintened…
